Laser engraving problems
Results 1 to 10 of 10
Thread: Laser engraving problems
    Member ninainwa's Avatar
    Aug 2019
    Default Laser engraving problems
    here are the pictures, the before is how small my text is and when I went to preview or print, it come out huge
    Attached Thumbnails Attached Thumbnails Laser engraving problems-test1-jpg   Laser engraving problems-test-2-jpg
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Laser engraving problems
    I don't see a problem. Your text is exactly the same size (96x62mm) in both the program window and the preview window.
    Jan 2008
    is the program bed layout the size of your bed.
    Aug 2019
    so for bugging you so much, but how do I change the size of my bed layout, I have I believe a 700mm x 500mm
    thanks
    Jan 2008
    Open your RDworks and under config there is page settings you can change it there
    Sep 2005
    Bed size has nothing to do with it. If you set your text size 96mm x 62mm thats what the machine should cut. Unless you have a mm to inches conversion going on or a scaling issue.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  7. #7
    Aug 2019
    not sure if i have mm to inches conversion going on, how do I fix that
    thanks
    - - - Updated - - -
    thanks, can't wait till I get home to try it out
  8. #8
    Sep 2005
    You say Print or Preview? If you convert to gcode how big does it actually cut, set your machine zero up so it just cuts in the air. If it try's cut or engrave 96 inches instead of 96 mm you will see.
    Most if not all Chinese lasers are set up for mm's. My USA made ULS could do either inches or mm's,
  9. #9
    Aug 2019
    how do I do that?
    thanks
  10. #10
    Jan 2008
    under config para settings DXF MM or Inch
