I tried to download it to my computer, but I don't know what program to save it as. It is trying to save as a rdworks file? instead of just unzipping onto a saved file?
I did figure how to get the para onto the laser, but now when I print, It wants to print huge, no matter how small I make the it..Could you help me on that,,,you have helped so much, thank you.... I still can't get the laser to go to home base, but at least it is moving up and down smoothly..thanks
First off cut a square that is say 100mm X100mm that you can measure. Then go into your vendor settings and read the file then save it so you can always go back to it. Change the step length for each axis by one half now if you are using my parm it will be .3500 so change it to .1750 and then write that to your controller then cut the same square. measure it and see what the difference is you can the adjust from there either up or down. Hope this helps
My best advise is to see if your vendor will send you the file for your laser. If that doesn't work Still try cutting a 100 x 100 mm square and see how close it is. If it is still to big divide your step number in half and cut again you should get pretty close then just keep adjusting until you get the square to cut 100 x 100 I will have to see if my old laser has the file you need.
