laser engraving problems
Results 1 to 11 of 11
Thread: laser engraving problems
    Member ninainwa's Avatar
    Aug 2019
    Default laser engraving problems
    I did a reset on my laser engraving machine and this happened:
    Then I was told to touch the limit switch and now it doesn't want to go up and down and barely move side to side. Any help Please
    Jan 2008
    Default Re: laser engraving problems
    Can you get the vender to send you the parameters for your machine to reload. any time you want to make changes you should save your settings so you can restore them if things go wrong or if you have a controller failure
    Aug 2019
    Aug 2019
    Do you know how I would enter the parameters, if the vendor sends them to me
    Member Mecanix's Avatar
    Aug 2019
    I'd search for the User Manual on what appears to be a "Ruida Laser Controller". I bet the info is all in there, troubleshooting, or you can find video referencing to setting-up the Ruida Controller on YT and elsewhere.
    Side note; look as if the motor got stuck on the limit switch (your 1st vid). I'd ensure that the motor is functioning correctly and that the limit switch is not engaged/bent/damage.
    Jan 2008
    RD8888 is the password
  7. #7
    Aug 2019
    so they sent me a link for the parameters to upload to the machine
    https://drive.google.com/open?id=1t2...h6SFXVVNBd9trI
    but I do not know how to upload this, any help...THANKS
  8. #8
    Jan 2008
    Download the file put it where you can find it then go to your RDworks and open vender settings you should see open open the file you downloaded and then write to the machine
  9. #9
    Aug 2019
    I tried to open it with RDworks, but It's giving me an error message. Can you send me a link to the RDworks, that will open this. Thanks
  10. #10
    Jan 2008
    Did you open your RD works like you were going to use it then go to file and then vendor settings
  11. #11
    Aug 2019
    yes I did, thanks I found it, but now I don't know if the para.. are set right, my machine is still acting weird
    how can I send you a screenshot
    thanks
