Need Help! Help please - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Help please
  1. #13
    Nov 2015
    Default Re: Help please
    If I have to guess the first sample (the shield) is done with a cheap Chinese DC laser.
    The second (the Jocker) with an expensive Servo/RF machine. That's why the curves and corners are clean and uniform.
    It is a good comparison between low and high-class machines.
  2. #14
    Mar 2015
    Both are made with the same machine for sure and it runs stepper motors.i made some tests and you can see my reslult in the photo.i increased the power gradually and lowered the speed.i also moved down the head of the laser by 0.5mm each time.as i lowered the head the plexi got blurry so i decide to keep the original position of the head and play with the power and speed.also aftrer the cuts i cleaned every single one with a mix of water and glass cleaner and i noticed that the lines went less white than what they were before the cleaning prosses.i also rotated the design and bnow its sitting on the back side of the plexi which made a huge differecne.any idea how can i clean the blurry plexi?
    thank you all for your help and looking farward for your suggestions on the result.Help please-20190815_100157-jpgHelp please-20190815_100150-jpg
    Attached Thumbnails Attached Thumbnails Help please-20190815_100157-jpg   Help please-20190815_100150-jpg
Help please
Help please
Help please
