Plastics cutting plastic
Results 1 to 2 of 2
Thread: Plastics cutting plastic
    Aug 2005
    united states
    Default Plastics cutting plastic
    Hello all
    I am cutting circles out of cast acrylic material. The material is .07" thick. The diameter of my circles are supposed to be .093". I am using a speed of 25 mmps and my laser is 25% max power using a 120 watt Co2 laser with 2.0 focal length eye.
    I am finding that there is a taper on the parts with about a .004"-.006" difference between top and bottom of part (top is .093" bottom is about .087"
    Does anyone have any suggestions on how to make my parts more uniform or is this simply the way lasers cut?
    Should I try increasing/decreasing my feed or power?
    I am very new to using a laser by the way.
    Any help or suggestions would be greatly appreciated.
    Cheers
    Member TokinSpokane's Avatar
    Mar 2019
    Default Re: Plastics cutting plastic
    Adjust your focal length down by 1/2 - 1mm at a time. And do test cuts till the diameter matches.
    Sent from my SM-G935F using Tapatalk
    TokinSpokane
    Custom Crafts
