Hello ALL,
I got a 600x400 Laser CO2 machine.
I can cut out the mica 5mm, but I can't do that with MDF Wood 5.5mm.
I had set Speed 15mm/s and amper 45.
What do you think are the chances the machine caught fire and burned down ttnc4plus?
fixtureman1 has the right idea to check the air assist, on a machine that large, would be surprised if there wasn't one, my school's 60w laser was cutting worse than a 30w laser all because of a loose bowden tube connection. Otherwise, what are your settings?
