Laser Cut a Wooden Spongebob Model
Results 1 to 2 of 2
Thread: Laser Cut a Wooden Spongebob Model
    Jun 2014
    China
    Default Laser Cut a Wooden Spongebob Model
    Laser Cut a Wooden Spongebob Model-01-jpg
    Today I am telling you how to make A Spongebob. Making Sponge Bob is easy! All you need is 5 mm plywood and a designs. Now is going to use a Thunder Laser system to make a Sponge Bob. Let’s start to explore fun with the laser!
    Attached Thumbnails Attached Thumbnails Laser Cut a Wooden Spongebob Model-01-jpg
    E-mail:nolan@thunderlaser.com facebook:https://www.facebook.com/ThunderLaser
    Facebook Laser Cutter Tech Support: https://www.facebook.com/groups/lasercuttertechsupport
    Member germanr's Avatar
    Aug 2018
    Buenos Aires
    Default Re: Laser Cut a Wooden Spongebob Model
    It looks very good.
    It would be great if you shared the cut file in vectors for the community.
    regards
    I am an experienced laser technician.
    User of laser cutting machine Buchicnc EVO 14.
    User of laser recorder EVO 5.
    CNC router user, with 3 x 2 m table Auto Tool Changer
    I usually design my own laser files designs for laser cutter & laser engraver with CorelDraw, Laser Cut 5.3, RDWorks V8.
    Laser cutters & CNC Routers BuchiCNC USA
    CNC Router ATC
    EVO 14
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
