Add laser to cnc router to cut foam
Results 1 to 6 of 6
Thread: Add laser to cnc router to cut foam
    May 2014
    Default Add laser to cnc router to cut foam
    I have a 4x8 cnc router. I am wanting to add a laser to it to cut out 1/4" foam for RC planes. Is there a simple add on laser i can mount to do this? WOuld be nice if it could cut very thin wood as well. Sorry if this has been cover, i just dont even know where to start to look for this information
    Sep 2009
    South Africa
    Default Re: Add laser to cnc router to cut foam
    Maybe a 15watt diode laser
    Sent from my SM-N960F using Tapatalk
    May 2014
    is there a full kit for this? Not so great at piecing stuff together. I did all the electronics on my router, but im not sure all the parts i need to get a laser to function properly
    Sep 2009
    South Africa
    You can check on aliexpress and I am sure you may find mount brackets etc
    ZAR 2,389.94 54%OFF | 450nm 15000mW 12V High Power TTL Adjustable Focus Blue Laser Module DIY Laser engraver accessories 15W laser head
    https://s.click.aliexpress.com/e/cc3lZhbw
    Mar 2003
    Shelby Township
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Nov 2010
    Poland
    Diode lasers are fragile. Wouldn`t invest. CO2 are simple and much more resistant for faults.
    CNC lasers, constructions, service
