stainless steel keychains and jewelry
Results 1 to 5 of 5
Thread: stainless steel keychains and jewelry
    andylsmith's Avatar
    May 2019
    Default stainless steel keychains and jewelry
    Im looking for a low cost machine capable of cutting and engraving stainless steel keychains up to 2mm thick and small logo type jewelry. Im trying to stay around the $10k range if possible.
    something similar to these:
    Member oneeye's Avatar
    Aug 2005
    Brazil
    Default Re: stainless steel keychains and jewelry
    Hi, so you need two machines.One Fiber marking machine with 50W ou 100W to engraving and one Fiber cutting machine 700W or 1000W , but not normal fiber source, a NLight fiber source is needed , Fiber cutting machines with normal fiber source can´t cut reflective metal cause beam is reflected back to source and will damage. You will spend about $45000 in a 600x400mm 700W machine with nLight source and about $10000 in a fiber marking machine.
    Member Opticlaser's Avatar
    May 2018
    Shenzhen
    Fiber laser marking machine is good for engraving.A low cost machine can be $3000.Fiber laser cutting machine is expensive.
    Nov 2010
    Poland
    Quote Originally Posted by Opticlaser View Post
    Fiber laser marking machine is good for engraving.A low cost machine can be $3000.Fiber laser cutting machine is expensive. ]
    $3000.Fiber laser marking machine is flat marking capable only. For deep engraving you need 50-100W Fiber machine that cost much more than $3000
    CNC lasers, constructions, service
    May 2018
    Shenzhen
    Yes.If you just want to mark the logo and make it visible then a 20w machine is ok.But if you want to deep engraving or cutting metal then you need 50w-100w.The speed of cutting is slow and the thickness should be under 1.5mm.
