Depends upon laser. RF excited has better beam quality than DC. Much better.
Hey guys
What is the effective beam length of a laser? I.e. if you have a cut length of 2000mm in X and 1000mm in Y plus beam that isnt over the cutting area, say 200mm, then you may have a beam.of 3200mm+ from laser to material.
What loss does one experience?
Sent from my SM-N960F using Tapatalk
CNC lasers, constructions, service
Any power loss would be insignificant to cause any problems with engraving or cutting.
Bed leveling across all four corners would be a more significant area to concentrate on if there are any inconsistencies.
TokinSpokane
Custom Crafts
