Laser cutter beam length limitations
Results 1 to 3 of 3
Thread: Laser cutter beam length limitations
    Sep 2009
    South Africa
    Default Laser cutter beam length limitations
    Hey guys
    What is the effective beam length of a laser? I.e. if you have a cut length of 2000mm in X and 1000mm in Y plus beam that isnt over the cutting area, say 200mm, then you may have a beam.of 3200mm+ from laser to material.
    What loss does one experience?
    Sent from my SM-N960F using Tapatalk
    Nov 2010
    Poland
    Default Re: Laser cutter beam length limitations
    Depends upon laser. RF excited has better beam quality than DC. Much better.
    CNC lasers, constructions, service
    Member TokinSpokane's Avatar
    Mar 2019
    Any power loss would be insignificant to cause any problems with engraving or cutting.
    Bed leveling across all four corners would be a more significant area to concentrate on if there are any inconsistencies.
    TokinSpokane
    Custom Crafts
