Hi everyone.
Need a little advice.
Just built myself a laser 1200mm x 600mm bed size with 100 watt tube. Just finishing the wiring at present. I have used mechanical micro switches for all axis but I want to use an inductance switch for the lid. I have the usual Chinese 6 to 30v switch with brown = +, Blue = - and Black is the signal.
I am obviously going to connect to the AWC controller via block 11 using input 1. This has 24 volt output and a ground plus signal inputs. My question is can the controller take a 24 volt input signal or will I have to use a 10k resistor to reduce the input voltage to 5volts. Can't find any info in the manual or online and I have even sent a message to Trocen but haven't got a reply.
Any advice would be grateful.
Paul
