Ruida Controller
Results 1 to 7 of 7
Thread: Ruida Controller
    Sep 2009
    South Africa
    Default Ruida Controller
    Hey guys, I have gone with a grbl controller BUT many spout Ruida. Now I Know Ruida is good, that is obvious BUT which one AND what do I lose going with a Ruida vs grbl?? I'm not fussed in what I gain either have their functions I.e. cut and engrave
    What are the pros and cons? Is there a site I can go to?
    Sent from my SM-N960F using Tapatalk
    Member germanr's Avatar
    Aug 2018
    Buenos Aires
    Default Re: Ruida Controller
    Hi Shearder,
    Grbl Controller is software that is designed to send GCode to CNC machines. It isn't super smart, it just needs to give the user a nice way to get commands down to whatever controller they are using.
    A Ruida controller includes two things:
    1- The necessary hardware to control a laser cnc system (can control: drivers, power supplies, sensors and came with a beautiful control panel with display to control the machine).
    2- A proprietary software to prepare the files called RDWorks.
    The controller Ruida is like a more "professional" option.
    More simple to use, since the process of configuring files is more accomplished and is much more intuitive.
    Best wishes!
    we are:
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
    Sep 2009
    South Africa
    Quote Originally Posted by germanr View Post
    Hi Shearder,
    1- The necessary hardware to control a laser cnc system (can control: drivers, power supplies, sensors and came with a beatifull control panel with display to control the machine).
    Best wishes!
    we are:
    BuchiCNC USA
    Great CNC Router:
    CNC Routers
    Many thanks for that. Once the grbl gets here i will test it out via an offline control panel and if it doesnt do it for me I'll go Ruida.
    Sep 2009
    South Africa
    Hi Shearder,
    Best wishes!
    we are:
    BuchiCNC USA
    Great CNC Router:
    CNC Routers
    Which is the better Ruida controller as there are a few
    Aug 2018
    Buenos Aires
    We use the RD6442 model in our machines are very good for CO2 laser cutting machines.
    we are:
    BuchiCNC USA
    Great CNC Router:
    CNC Routers
    Sep 2009
    South Africa
    Ok there is also Trocen.
  7. #7
    Sep 2009
    South Africa
    we are:
    BuchiCNC USA
    Great CNC Router:
    CNC Routers
    How is 6445g?
Ruida Controller
Ruida Controller
