Need Help! Y-axis cutting quality
Results 1 to 2 of 2
Thread: Y-axis cutting quality
    Apr 2019
    Default Y-axis cutting quality
    Hi, I have problem with 250W CO2 metal cutter. If y-axis moving down the
    cutting line is fine. but moving in oposite
    direction the cutting line is very poor.Have there eny common
    reasion?
    Member germanr's Avatar
    Aug 2018
    Buenos Aires
    Default Re: Y-axis cutting quality
    Did you check the calibration of the mirrors? between the mirrors 2 and 3 is the calibration of the X axis. I think the problem may be there. Logically I am talking about an optical system with 3 mirrors.
    Regards!
    we are:
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
