K40 laser problems when turning on
Results 1 to 3 of 3
Thread: K40 laser problems when turning on
    Member iDaniel88's Avatar
    Apr 2019
    Default K40 laser problems when turning on
    I recently bought a SH K40 Chinesse laser engraver and I tested by pressing the "Laser switch", adjusting the current regulation, adjusting the mirrors and stuffs like that. By doing that I think I break something, or something happened with the rail because when I try to move the laser head from the K40 Whisperer, it does initiaze, I can move the Y axis by pressing the arrow down, but when I try to move the head to the right, nothing happened. Try this several times, no result.
    The last thing that I saw is that every time I hit the Initialize Laser it will go down a little bit until it will hit the limit.
    Video to see that the X axis is not responding : https://streamable.com/yetr2
    Found out this large white wire was being pulled out from the stepper...
    Ok so I plugged in the white wire back into the stepper... and the laser went crazy. I also tried to flip the wire in the plug but it behaves like it was in the beginning with no response from the X axis. Somehow now the axis are moving but terrible wrong...
    Video here : https://streamable.com/vrifo
    I don't have a clue what could possibly went wrong with this laser machine.
    Any advice would be helpful. Thank you !
    Feb 2009
    Default Re: K40 laser problems when turning on
    Check the belt and pulley. Can you slide the head easily by hand? Sounds like it's trying to reference.
    Apr 2019
    Hi underthetire, yes when the laser is turned off I can easily slide the head left and right. Can this be a hardware issue ? the way it's behave ? Should i replace the stepper ? Really don't know what to do
