Need Help! DTML-F(I)Pulsed Fiber Laser
Results 1 to 2 of 2
Thread: DTML-F(I)Pulsed Fiber Laser
    Default DTML-F(I)Pulsed Fiber Laser
    I had a Chinese Fiber laser unit for 2 years
    Model: DTML-F(I)Pulsed Fiber Laser 5w-30w, IPG-YLP Control Card, EZCAD 2.5.3
    After initial power-up:
    I/o 4 input is on, light fires OK, but Marking is very Weak, I/o 4 input turns off.
    the second try to mark Ezcad displays "IPG Laser:System Error!"
    I believe either the software is not set up correctly, or the Laser Source is bad.
    please guide me what is the problem and how to fix it
    Member Opticlaser's Avatar
    May 2018
    Shenzhen
    Default Re: DTML-F(I)Pulsed Fiber Laser
    What laser source are you using?Is it in warranty?You can contact with your Chinese supplier.
