Need Help! 50w laser engraver
Results 1 to 8 of 8
Thread: 50w laser engraver
    Member TokinSpokane's Avatar
    Mar 2019
    Default Re: 50w laser engraver
    The photo is not clear. Are you saying it's good, or bad?
    Sent from my SM-G935F using Tapatalk
    TokinSpokane
    Custom Crafts
    Member craigleon123's Avatar
    Mar 2019
    Quote Originally Posted by TokinSpokane View Post
    Bad its got a pattern on it and it suppose to be smooth
    Mar 2019
    I have one of these 50 watt lasers also. I'm still not sure if I'm understanding what your problem is. Are you saying it has a deep texture & you want it more smooth? Give as much detail as you can. Are you new to lasers?
    TokinSpokane
    Custom Crafts
    Mar 2019
    Yes I'm new to laser engraving I would like it to smoother as it is leaving a deep texture we're it has engraved
    Mar 2019
    Lower your power setting to max 15%. Then set your speed to 50mm per second. Run a test to check the quality. Set the speed higher or lower until you get what you want. Different woods may need different speeds because of density. Try that out and see if it works.
    TokinSpokane
    Custom Crafts
  7. #7
    Mar 2019
    Default Engraving problems
    I'll have a go thanks. Also I think the laser is only engraving one direction is that normal?
  8. #8
    Mar 2019
    Default Re: Engraving problems
    Quote Originally Posted by craigleon123 View Post
    1st keep the power at 15% & increase the speed to 300mm per second.
    2nd click on "path optimization".
    3rd always run the simulation. It will show you exactly how your image will cut, power, speed, the direction of the laser head movement & the time it will take from start to finish.
    TokinSpokane
    Custom Crafts
50w laser engraver
50w laser engraver
