I had a Fiber laser unit for 2 years
Model: Pulsed Fiber Laser 5w-30w, IPG-YLP Control Card, EZCAD 2.5.3
The light fires OK, but when Marking it displays "IPG Laser:System Error!"
I believe either the software is not set up correctly, or the Laser Source is bad.
please guide me what is the problem and how to fix it
Turn on your laser source. I've had that error plenty of times and it's always when I forget to turn on the switch. If the switch is on then start checking to see if you have power to this source.
I am also facing same issue in IPG Ylp 30w, I am also using same Ecad 2.14 software and same way there is one errors showing in machine “Fiber laser system error ” so if anyone have a Solutation then please let me help and tell me the reason and solution for the same
