Fiber laser cleaning machine for metal and non-metal rust removal
Results 1 to 2 of 2
Thread: Fiber laser cleaning machine for metal and non-metal rust removal
    Reaying's Avatar
    Feb 2019
    Default Fiber laser cleaning machine for metal and non-metal rust removal
    Molds, weapons and equipment, precision machinery, the electronics industry, often need to remove products, equipment, surface rust, oxides, pollutants. The traditional chemical or mechanical way to remove incomplete, damage to the matrix material defects, by contrast, laser cleaning is a green, flexible and efficient way to clear, to ensure the removal effect, while almost no damage to the matrix material , Can be flexible to deal with a variety of shapes and sizes, low power consumption.
    Principle and Application of Laser Cleaning
    Laser cleaning is based on the photophysical reaction between the laser beam and the pollution layer. There are two main ways of laser cleaning: First, the laser is absorbed by the pollution layer on the surface of the material. First, the plasma is formed by the laser, and the shock wave, shock wave So that contaminants become debris and be removed.
    Laser cleaning can not only be used to clean organic pollutants, can also be used to clean inorganic, including metal corrosion, metal particles, dust, can be used for mold cleaning, cleaning equipment, electronic industry, precision machinery cleaning, cultural relics Cleaning and so on.
    MAX Pulse 100W Laser Cleaning Case
    Using the MAX Pulse 100W pulsed laser developed by Chongxin Laser, it can realize the high-speed cleaning of the pollutants on the surface of the material without damaging the matrix material.
    Product description
    It is suitable for the precision machining of stainless steel, copper, aluminum and other materials. It has small thermal distortion and high processing precision. It has the characteristics of narrow pulse width and high peak power. Its compact structure, easy system integration.
    More>> https://www.reaying.com/fiber-laser-...t-removal.html
    E-mail: info@reaying.com
    Nov 2010
    Poland
    Default Re: Fiber laser cleaning machine for metal and non-metal rust removal
    How much it cost?
    CNC lasers, constructions, service
