Laser Pulse control
Results 1 to 9 of 9
Thread: Laser Pulse control
    Registered bjwx2's Avatar
    Dec 2017
    Default Laser Pulse control
    Installed a 15 watt laser on my engraver. Laser works fine in stand-alone mode but cannot control pulse on\off with my controller. I assume the TTL plug-in is what
    controls the pulse? Using a Keyestudio rev 0.9 with GRBL. Any help greatly appreciated!
    Aug 2014
    Default Re: Laser Pulse control
    Really not enough information to go on to give an answer.
    Dec 2017
    This is how I have it hooked up. Shouldn't the input marked laser control, control the laser pulse?Laser Pulse control-laser-control-jpg
    Attached Thumbnails Attached Thumbnails Laser Pulse control-laser-control-jpg
    Aug 2014
    Have you configured grbl to enable laser?
    Dec 2017
    How would I do that, thanx
    Aug 2014
    Do some research. It’s well documented
  7. #7
    Dec 2017
    Thanks soooooooooo much for your help.
  8. #8
    Aug 2014
    You’re welcome. It’s always gratifying to see people making the effort and not just sitting back and wanting to be spoon-fed.
    Thats how I learned. It has paid off, handsomely.
    And FYI, the most powerful diode laser made is ~6.5W, so you were ripped off with your ‘15W’ unit. It’s an over-volted 6W unit. You’ll be lucky if it lasts 200 hours.
    Here, as I’m feeling generous: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Laser-Mode
    Just as a pro tip, I typed ‘grbl laser’ into google and it was the first entry that presented itself.
  9. #9
    Dec 2017
    Quote Originally Posted by ledaero View Post
    Have done my research I know that $32=1 turns laser mode on and 0 turns it off. Have PWM connected to TTL output, but laser still does not turn on and off as it should, could I possibly have a defective controller for the laser?
Laser Pulse control
Laser Pulse control
