Is this tube 80 or 100w?
Results 1 to 9 of 9
Thread: Is this tube 80 or 100w?
    *Registered User* pakt's Avatar
    Oct 2018
    Default Is this tube 80 or 100w?
    2 days ago i reiceived mine 1390 co2 laser with 80w reci w1 tube.
    I not need big wattage tube because im interesed more on engraving.
    At power supply and at tube is written that is 100w.
    Whats the real power of this tube?
    Oct 2018
    Default Re: Is this tube 80 or 100w?
    Bump..anyone can help me pls?
    Nov 2015
    See if you can find the brand and the model number of the tube and check on the manufacturer website.
    It is possible what you see on the tube label (102.3W) to be the peak value, not the actual operational wattage.
    BTW this tube is a very poor choice if you intend to use the machine primarily for engraving. The 25-40W DC lasers have smaller fluctuation range and beam diameter, therefore the quality of the engraving would be significantly better.
    Oct 2018
    Quote Originally Posted by Storen View Post
    It is reci.
    Can you link me where to check because i dont find it.
    Nov 2015
    Quote Originally Posted by pakt View Post
    It is reci.
    Since you know the brand maybe you confirm the wattage by measuring the length of the tube. For some reason, I can't load the RECI's website but I remember they had a spec. sheet with the dimensions for all their models.
    Registered abyss's Avatar
    Oct 2015
    Ireland
    I remember some rumor year(?) ago about fake RECI tubes (@ ebay?) which was labeled RECI but was not even physically identical to their products. Unfortunately I don't heave links to that. Best way is to check real power (as Storen says) - this was my first idea. Small sellers from mass-sale portals feels unpunished.
    You can try to "do research" by visual comparison with web pictures, but this should be only additional action.
    Polish @ Éire
  7. #7
    Feb 2014
    China
    Did you test the machine, how's the engraving result?
    www.thunderlaser.com
  8. #8
    Aug 2014
    The Reci W1 is rated from 75w - 90w.
    The label rating is the peak measured power at the peak rated mA power input (29mA).
    The ‘agreed’ power is the rating at 27mA, which is ‘90w’.
    The rating at the most long-lasting setting, which is 25mA or less is 80W~
    I would set my PSU to ~20mA, if engraving was my primary focus.
    I would also invest in a Mahoney laser probe: https://www.bell-laser.com/product-p...be-0-200-watts
    A genuine Reci will have a QR code you can scan which will take you to the page for that exact tube. All the information you need is on there.
  9. #9
    Aug 2014
    Quote Originally Posted by abyss View Post
    Geniune Reci tubes have a QR scan code.
    Avoid adding to rumour by posting unsupportable advice.
    - - - Updated - - -
    W1 is 1050mm x 80mm
