Problem cut not straight
Results 1 to 2 of 2
Thread: cut not straight
    Registered Plan30's Avatar
    Feb 2019
    Default cut not straight
    Hello,
    I've got a problem with the cutting.
    Sometimes (no specific time, line, material...), the cut "shakes" !
    Has somebody an idea of my problem's origin ?
    Thanks !
    Vincent
    Attached Thumbnails Attached Thumbnails cut not straight-img_1798-jpg   cut not straight-img_1800-jpg
    Feb 2014
    China
    Default Re: cut not straight
    did you check:
    1. is the laser head loose?
    2. is the lens and mirror loose?
    3. is the belt loose?
    4. is the material loose?
    5. is the machine shake?
    www.thunderlaser.com
cut not straight
cut not straight
