Intermitent cutting
Results 1 to 2 of 2
Thread: Intermitent cutting
    Jun 2014
    Canada, USA
    Default Intermitent cutting
    Recently i have been experiencing intermittent cutting, but only the bottom part of the cut. Example when cutting a 15x15" part, the top part or the first 10 to 12' is perfect, but the last 3 to 5" is were the problem begin. It will cut for a while and then no burn at all for a small part up to sometime 1/2" or even a little more. After cutting is done I redo the cutting job and some of the mist cut are now cut except for still a few place not done. I've cleaned the lens and mirrors and even reline the laser but still have the problem. Can anyone help.
    Jan 2008
    Default Re: Intermitent cutting
    have you aligned your mirrors and is your bed parallel to your lens all the way around
Intermitent cutting
Intermitent cutting
