You would need a wider single line or just reduce the power also
Not sure what I'm doing wrong but if draw a straight line in Lasercad and select engraving I get a "No Data Found" error when I try to download, if I select cut it transfers to the machine OK but I want to engrave the lines not cut .
Same things occurs if I import a file with straight lines.
Any help / advice would be appreciated.
Fred
