Had to switch controllers and install new endstops but can't figure out how to wire them. Posting pics of the controller and end stops, maybe someone has used
these and can tell me what I'm doing wrong, thanx
You have 6 pairs of pins for 6 "end stops" (more commonly called "limit switches"). Just connect each switch to its own pair of pins. Use the normally closed contacts on the switch, leave the third contact disconnected.
Tried this, no luck, have never had a problem with this before, e-stop, hold and resume all working fine, just can't figure this one out. Brand new controller, but may be defective?
