Newbie max cutting depth question
Results 1 to 3 of 3
Thread: max cutting depth question
    Registered cromag27's Avatar
    Apr 2017
    Default max cutting depth question
    if a machine is rated at max cutting depth of 5mm, is that in a single pass? can you make multiple passes to cut deeper?
    i cut acrylic up to 1/4” and trying to find the correct wattage to use. thanks.
    Jan 2008
    Default Re: max cutting depth question
    I have a 60 watt and a 130 watt laser and cut a lot of 1/4 acrylic first thing is use cast acrylic as it cuts easier and better. I can cut 3 times faster with the 130 watt so you will want the highest power you can get
    Apr 2017
    Quote Originally Posted by fixtureman1 View Post
    great, thanks for the feedback.
