Need Help! voiern wr4040 laser cutter default settings
Results 1 to 7 of 7
Thread: voiern wr4040 laser cutter default settings
    Feb 2010
    Question voiern wr4040 laser cutter default settings
    Hi, I need a little help and wondered if someone could help me out, I recently bought a voiern wr4040 laser cutter equiped with a RDC6442G "Ruida" controller. The Machine was working great, until I messed up a few setting and had the bright idea to do a parameter reset, thinking it would put the setting back like they where when I got the machine, but instead it reseted all setting to default for the DC6442G. Now the machine doesn't go to home, goes reverse in the y axis and move super slow. Contacted the seller but still haven't answered me. Anyone got a similar machine and can get me the default setting ?
    Feb 2010
    Default Re: voiern wr4040 laser cutter default settings
    Ok, I got some of the settings back by myself and can use the machine again, only problem is : the laser power seem a lot weaker then before, when I tested it using the pulse button I was making a hole in 3mm wood pratically instantly, now it doesn't make it trough even if i hold the pulse for a few seconds. tested with a cut i used to be able to make trough the same wood in one pass and now it doesn't even go halway when cutting. Did I somehow bust the laser some way or is there a setting I messed up ?
    Registered puribogdan's Avatar
    Feb 2019
    I have the exact same problem. Did you manage to fix it somehow?
    Member carlalvey's Avatar
    Sep 2020
    sorry to jump on the thread but can i ask where you bought it from im looking to get the WER-6040 and looking to find a supplier rather than go direct to china.
    cheers in advance.
    Feb 2010
    Quote Originally Posted by carlalvey View Post
    cheers in advance.
    Can't really help you there as buying it directly from china is what I did back then. I looked at buying it from a reseller closer to home, but that more then doubled the price of the machine !
    Member H120's Avatar
    Oct 2020
    Quote Originally Posted by mekanofreak View Post
    Hi i am having the same problem, can you share the settings?
  7. #7
    Feb 2010
    Quote Originally Posted by H120 View Post
    Well, My laser is not functional at the moment. I just moved into a new house and had no time to set it up, but I will either try to find the file I got the parameters from, or I will try to plug it in and get the config directly from it if you can wait a day or two.
