Problem - CO2 machine skews to the right when engraving
Results 1 to 1 of 1
Thread: Problem - CO2 machine skews to the right when engraving
    *Registered User* snopa's Avatar
    Sep 2018
    Default Problem - CO2 machine skews to the right when engraving
    Hello,
    I have problem with CO2 laser machine size 130x90cm when i want engraving it. all the time gently moves to the right.
    I think the problem may also occur when cutting, but it is more noticeable when engraving due to the many repetitions of Y-axis motion.
    In the pictures you can see what I mean.
    For now, I only corrected the tension of the Y-axis belt, it did not improve the work.
    Can i correct this on controller RDC6442G ? Or where i shroud search to solve this problem?
    Attached Thumbnails Attached Thumbnails Problem - CO2 machine skews to the right when engraving-1-jpg   Problem - CO2 machine skews to the right when engraving-2-jpg
