Need Help! Mutoh iP-530 Plotter
Results 1 to 3 of 3
Thread: Mutoh iP-530 Plotter
    Registered bplail's Avatar
    Dec 2018
    Default Mutoh iP-530 Plotter
    Hey guys!
    Just joined the forum
    I recently picked up a free Mutoh iP-530 plotter and was hoping to get it working and eventually turn it into a vinyl cutter. I've read around on here that it can emulate a HP 7580. I've got no idea where to start on software for this thing so was hoping for some guidance and also some help getting it to talk to the computer. I've ordered a parallel cable to get me started but other than that not sure where to go after that. There isn't any manuals for this model specifically. Closest I can find is a manual for the xp 510 https://www.manualslib.com/manual/10...oh-Xp-510.html
    I was hoping to start off by getting it to plot basic vector files with a pen manually placed in the holder and not using the carousel, so from there I can put a knife in and then start cutting vinyl.
    Any help is appreciated, I can upload some pictures later too if need be
    galo's Avatar
    Feb 2021
    Default Re: Mutoh iP-530 Plotter
    Hello, i am in the same boat! i have on too. what os are you running, i have a HP DraftPro EXL running great with windows xp and using the DraftProRoland GRX-450 Driver. Did you find any solutions for yours? I have the full manual in case you also need it.
    Best
    g
    Member Shade820's Avatar
    Mar 2022
    Post Re: Mutoh iP-530 Plotter
    Quote Originally Posted by galo View Post
    Best
    g
    I have a IP530 plotter you posted you have a manual for it. Is there any way I could get a copy? I can not locate online any where.
    Member ATOVAN's Avatar
    Jun 2022
    I have manuals, and am using Winline for my drivers, they are out of Australia. Pricey, but worth it to utilize the plotter/cutter. I've spoken with them, and they recommended the best driver, and it isn't what is most recommended on the forum.
    Jun 2022
    Forgot to mention I am running Windows 10
    koalarobert's Avatar
    Sep 2023
    Hi!
    Did anybody here made it work so far?
    I'm using a properly jumpered serial cable but still nothing. If you have the manual available I would love to see it! Thanks in advance for any help
