Need Help! Corel laser axis configuration
Results 1 to 2 of 2
Thread: Corel laser axis configuration
    *Registered User* tato_6_6_6's Avatar
    Nov 2018
    Default Corel laser axis configuration
    Hello good day.
    I have a problem with my laser machine and I can not find any information on how I can fix it. After an intense search I found this picture and I think maybe someone who can help me. I want to configure the motor step of the axes and I do not know how I can do it. Does anyone know how I can ?.
    My software is the Corel laser 2013.02.
    My Axis controller is a LIHUIYU M2 Main Board Co2 Laser Control.
    My cnc is a Chinese K6040w with 80w tube.
    I want to thank you for your time and help first of all a greeting.
    Nov 2008
    Default Re: Corel laser axis configuration
    it looks like that main board also drives the steppers. So the stepper movement per pulse is built in to the board and probably not adjustable. In looking at that software you simply choose the main board so the motor step size is all calculated for you. meaning the pulleys are standard. if you can adjust the step size just start somewhere and tell it to create a square. keep playing with the number until the shape is the correct size. you really cant hurt anything if this number is off.
