Advice on cutting PE open cell foam - 30mm
Results 1 to 5 of 5
Thread: Advice on cutting PE open cell foam - 30mm
    Default Advice on cutting PE open cell foam - 30mm
    Hi Folks, i've recently purchased a 100w Co2 laser and having a few problems. Firstly, i am not getting "clean" cuts through the material - it looks fine on top, but its rough as heck at the bottom. It looks like it burns and melts the material. The material is 20mm 12kg/m PE opencell sponge foam.
    This video and sample was done using a laser head - 20 dia, and focus lens 60.5FL
    Could i kindly ask for some suggestions on the laser cutter settings you use? your lens, head and FL?
    Secondly, any advice on how to prevent the blackening / charring of the material on the bottom?
    see video here:
    https://s3-ap-southeast-2.amazonaws....906_112608.mp4
    sample cut here:
    https://s3-ap-southeast-2.amazonaws....m/test+cut.jpg
    thank you kindly
    Jan 2008
    Default Re: Advice on cutting PE open cell foam - 30mm
    I would try a pin bed. I made one using pop rivets. If you can keep the foam up it may cut through cleaner as it is not getting the flash back
    Registered GerryG's Avatar
    Sep 2018
    Either a pin bed or a hex mesh bed will help with the charring and flash, but that sort of thickness is going to have significant focal issues at the lower end - unless you're using a machine with really decent optics, you're going to lose focus to a significant degree after the first ten mm.
    As a rule, drop the speed a fair chunk and power a bit - I tend to go with 30:20, so take 30% off the speed, and 20% off the power if I'm working with stubborn materials. I know it sounds a bit counterintuitive - the obvious thing to do is to crank the power up, right? Well, proportionally speaking, you are. You'll generally get a cleaner cut, and can dial the speed and power in a bit more afterwards. If you just crank the power up to account for it instead, you'll usually get more charring.
    Jan 2008
    You could lso try a 4 inch focal lens
    Hi Folks, thanks for the replies - super helpful. I'll try and order a 4" FL, is there any particular brands or types that you'd recommend?
    Can i also ask, Fixtureman1, would it be possible for you to post a picture of the pinbed?
