I'm at my wits end. Recently bought the 7W J Tech Photonics laser. We intend to use it on our 4x8 Gryphon CNC table. Presently we just have the router hooked up. I feel like I have connected EVERYTHING imaginable, but I still can't get the mach3 to run the code. typically we do all our programming in Fusion 360, but apparently Fusion isn't a big fan of doing too detailed of work for laser toolpath. Inkscape (with the JTech plugin) WILL make a gcode for laser cutting, but once loaded into mach3, nothing happens.
