Problem K40 engraving lighter stripes
Results 1 to 2 of 2
Thread: K40 engraving lighter stripes
    *Registered User* APIC0's Avatar
    Sep 2018
    Default K40 engraving lighter stripes
    Hello, on my Brand new K40 i'm experiencing power losses during engraving. It appears as lighter stripes or areas. No matter the speed (tried from 100 to 600mm/s), laser power, material or engraving orientation nor position on the work area. Focus and alignment seems fine, cut is perfect all over the surface. Attached picture is an example.
    Any hint would be appreciated.
    Attached Thumbnails Attached Thumbnails K40 engraving lighter stripes-20180921_211824-jpg
    Sep 2018
    Digging more deeply, i found that machine fails to engrave when picture contains much black areas.For instance, a black rectangle will not be engraved at all. A loud arching noise is is heard from psu or tube.
    Any help?
