Need Help! Bystronic bystar 3015 btl 2800 operating help
Results 1 to 3 of 3
Thread: Bystronic bystar 3015 btl 2800 operating help
    Joerocket's Avatar
    Sep 2018
    Default Bystronic bystar 3015 btl 2800 operating help
    Hi we just bought a co2 bystar 3015 btl 2800 1994, the resonator start fine, when I start a job I get a message like on the first picture, the machine do her cycle cut for a second (only make a point hole in the sheet). Can someone help me to point out my problem that is link with the message “working: abort at record number n2/1003” the mécanisme just stop there and ask me to go back to the reference point. If my explanation is not clear please feel free to ask question. I'm a newbie in the laser world, i have a good background in waterjet
    Thank you
    Attached Thumbnails Attached Thumbnails Bystronic bystar 3015 btl 2800 operating help-d3306f31-464e-49b2-b1d4-ca436ae41093-jpg   Bystronic bystar 3015 btl 2800 operating help-96fb3e6b-1b79-4b20-8c5a-92fed631fce2-jpg
    Jan 2015
    Default Re: Bystronic bystar 3015 btl 2800 operating help
    Hello, i have a similar problem whit a bystronic waterjet running on cnc 90 from 1995 i got the error Abort at record number N4/1002 do you got alredy a solusion for your problem ?
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Jan 2015
    My problem is solved for your error n2 i think you need to change your start position of y axis at (hand - valve settings) or your axis hitting the reverence/limitswitch i got afther n3 also n2 beauce the y axis hitting the limit switch
