AWC708C lite - Advice on setting up
Results 1 to 2 of 2
Thread: AWC708C lite - Advice on setting up
    Dec 2017
    Default AWC708C lite - Advice on setting up
    Hey all,
    Building myself a laser cutter and am at the stage of setting up the controller.
    I have managed to get the home end stops going.
    I am mainly chasing any advice on the motor settings & speeds.
    Firstly, does anyone run microstepping for a laser cutter?
    Also does anyone have advice on the likes of acceleration/jerk.
    Also what speeds would people normally use for cutting, and for engraving?
    So i can set those speeds up when doing my testing.
    I just want to try and set all the mechanicals and do some realistic testing at normal speeds before
    i hook any laser gear up.
    At the moment I have the motors moving, but with horrible jerking. When i jog its pretty harsh on things.
    I'm running 2amp nema 17 motors of TB6600 drives.
    Any advice would be great!
    Nov 2008
    Default Re: AWC708C lite - Advice on setting up
    The goal is to set it up with the lowest Um/pulse setting possible or the design will get choppy. I don’t think you cant go less than 1 mine is set at 4.07. At 50 if you cut a circle the ends won’t align. This is with a single pulley belt drive. So yes microstep all you can.
