Hi all. Having trouble with my machine noticed recently when scanning the side of the scan cuts into the material then 1-3mm laser it seems the power drops to the other side. Causes problems when trying to cut 2 tobe material. Images attached How can i fix this any suggestions?Similar Threads: LASER MACHINE POWER CONTINUOUSLY HIGH SPEED .. POWER FALLING ... PROBLEM CAUSE SOURCE 50w laser power supply problem!!!Need Help!- Laser CO2 power problem.Problem- laser power problem Laser power output problem(unstable)!!!
View Tag Cloud
Forum Rules
