Sudden problem with k40 4060 laser
Results 1 to 2 of 2
Thread: Sudden problem with k40 4060 laser
    Jan 2018
    Denmark
    Default Sudden problem with k40 4060 laser
    Hello fellow Laserfreinds
    i am having a issue with my k40 4060 60w laser
    all of a sudden i lost connection to the laser, and i was not able to connect to it again. the "fire on" light is always lit, and the position laser is not working either.
    BUT i am able to fire the laser tube and it works fine.
    so i believe its the main board thats the issue, it is a model B1 which i am not able to find anything on and definitely not find a seller (See pictures)
    i can however find lots of M2 boards - Will that be a decent replacement? and easy to move over
    i also uploaded a picture of my low voltage powersupply which i also cant find anything on, and believe that could also be an issue
    any suggestions?
    Sudden problem with k40 4060 laser-img_0813-jpgSudden problem with k40 4060 laser-img_0816-jpg
    Attached Thumbnails Attached Thumbnails Sudden problem with k40 4060 laser-img_0813-jpg   Sudden problem with k40 4060 laser-img_0816-jpg
    Mar 2016
    United Kingdom
    Default Re: Sudden problem with k40 4060 laser
    hi
    The B1 is available in the UK from https://www.dropswell.com/shop/spare...ntrol-board-b1
    Dave
