Hi all,
Got a bit of a problem, I have installed this controller and all is working.
When you move the head with the key pad, the head moves in the correct way.
The trouble is that it thinks home is top left, and want it to be top right.
I have inverted on the the keypad screen, told RD works where the home is but still not going there.
The bed is 900 x 600mm, but it shows on key pad as 1000 x 10000 even though it is correct in RD
Help
Cheers
Pete
What size is shown when you do "read" in Vendor settings in RD Works? Probably there is your problem...
Laser connected directly through USB/Ethernet (!)
File(F)> Vendor settings [rd8888, be very conscious what you do there!] > Read(at bottom) > Motor/X/ Breadth mm
(same for Y)
If you change anything and want to send this setup to laser: "Write".
Read have to be always used at beginning of session before Write, as otherwise it will be no effective.
