Newbie Ruida Controller Crashed
Results 1 to 3 of 3
Thread: Ruida Controller Crashed
    May 2018
    Ireland
    Default Ruida Controller Crashed
    I need help with my KH-7050 Chinese laser cutter. Im very new to using this machine and am hoping that somebody out there can help.
    I started my machine this morning and all the settings from the controller are gone the machine starts up and the motors drive the head to the bottom left corner and pushes it past the stops that used to be there.
    I think the vendor settings in rd works is also after resetting itself i have been trying all morning to get it working again (with no help form the supplier) im just lost
    Can somebody who was one of the KH-7050 black and red laser cutter be so kind to send me on the the config setting for my machine
    Best Rergards
    Padraig Hill
    May 2018
    Ireland
    Default Re: Ruida Controller Crashed
    Hi All,
    Problem is now solved found vendor settings on line which fixed my issue!!!!!
    Registered abyss's Avatar
    Oct 2015
    Ireland
    Just in case anyone will have similar issue:
    When machine is starting use ESC key several times. This will avoid "bumping" of the head.
    By the way paudyh - what county you are? +Greetings from west co. Limerick
    Polish @ Éire
