Newbie What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000
Results 1 to 5 of 5
Thread: What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000
    Apr 2018
    Default What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000
    Hello,
    What are the best settings on a Trumpf L3030 TFL4000 to produce deep etching/engraving?
    This laser is a CO2 laser, this link has more information about the laser: CUTTING LASER MACHINE TRUMPF TYPE TC L3030 - TLF 4000 - USED YEAR 2001 - LIFT MA
    Currently at my company I was tasked with implementing engraving into our process flow. Unfortunately, no one at my company knows the best setting for engraving on our Trumpf L3030 TFL4000. I have contacted Trumpf on this matter but since we have a CO2 laser and not a fiber laser they were unable to assist me.
    Thank you
    Registered Bigbird48's Avatar
    Nov 2012
    Default Re: What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000
    Well If the company you bought it from can't help your in trouble. As Far as I know a CO2 laser won't engrave steel, you need a Fiber Laser for that.
    Apr 2018
    What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000-img_4287-jpg
    Our CO2 laser can engrave but we need it to engrave deeper.
    Attached Thumbnails Attached Thumbnails What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000-img_4287-jpg
    Apr 2016
    harvey engraving tool, 6000rpm, 4 ipm, 1 ipm feeding into part. thats what we do
    Apr 2018
    Tried a few test samples at different settings and this was the best that we came up with so far:
    Settings:
    Nozzle Stand Off: 0.31 in
    Laser Power: 400 watts
    Gating Frequency: 260 Hz
    Speed: 220 in/min
    Gas: O2 (Oxygen)
    Pressure: 2 Bar
    What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000-img_4328-jpg
    Attached Thumbnails Attached Thumbnails What are the best settings to use when engraving steel on a Trumpf L3030 TFL4000-img_4328-jpg
