Laser problem, please help!
Results 1 to 8 of 8
Thread: Laser problem, please help!
    Apr 2018
    Default Laser problem, please help!
    Hello everybody!
    Im new to the laser world, I have just got my 40w laser engraver, but when I connect everything and plug my lap nothing happens!
    When I remove the back, I see the laser go to a metal ring on the end of the tube instead of going thru.. any advice? thanks!
    Luis
    Laser problem, please help!-img_0383-jpg
    Attached Thumbnails Attached Thumbnails Laser problem, please help!-img_0383-jpg
    Apr 2018
    Default Re: Laser problem, please help!
    Really?? Nobody???
    Quote Originally Posted by lufegora View Post
    Hello everybody!
    Luis
    Registered Bigbird48's Avatar
    Nov 2012
    maybe no ones helping because theres so much info missing here and we can't understand the question n
    Apr 2018
    Hi buddy! Im sorry if I cant explain myself better..
    The thing is, that when I push the test button the laser appears inside the tube, but it does not came out of it.. the laser lands on a metal ring at the end of the tube.. I dont know what can I do to get the laser out of the tube.. is it the water sensor? or just a bad tube.. thanks!
    Quote Originally Posted by Bigbird48 View Post
    Registered jalessi's Avatar
    Feb 2007
    Items for Sale
    Post Re: Laser problem, please help!
    Lufegora,
    It appears as if you used tap water instead of distilled water.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2018
    Hi Jeff!
    I did use tap water, the ****ty chinese manual doesnt say anything about using distilled water, Im new to this laser world, I own a 3d printer and a small router cnc, and do know something about computers, but this laser technology is new to me. Do you think the distilled water will solve the problem or was just an observation? Thanks!
    Luis
    Quote Originally Posted by jalessi View Post
    Lufegora,
    Jeff...
  7. #7
    Feb 2007
    Items for Sale
    Flush the system complete out and use only distilled water, the impurities in the tap water are conducting which is causing the arcing!
  8. #8
    Mar 2016
    United Kingdom
    Luis
    You do realise that you cannot see the beam when it leaves the tube dont you (its invisible)
    put a piece of paper between the end on the tube and the first mirror and pres the test button, if the beam is presnt it will burn through the paper
    if it does then the chances are its just a mirror alignment problem
    Dave
