50W laser engraver cutting problem
Results 1 to 5 of 5
Thread: 50W laser engraver cutting problem
    May 2015
    Greece
    Default 50W laser engraver cutting problem
    Hello cnczone members!
    I have an issue with my laser cnc 50 w chinese cutter.
    I don't have clear cut. The cutting line is not smooth. I attached a photo with the problem. Has another member this issue?
    Thank you!!50W laser engraver cutting problem-30020421_10216514827293040_952559385_n-jpg
    Attached Thumbnails Attached Thumbnails 50W laser engraver cutting problem-30020421_10216514827293040_952559385_n-jpg
    Mar 2016
    United Kingdom
    Default Re: 50W laser engraver cutting problem
    hi
    looks like your pattern has been created in to lower resolution
    Apr 2018
    Bangladesh
    i hv no idea this problem.......................
    May 2015
    Greece
    The programof laser is RDWorks. I use Corel draw to make the pattern and i import the dynamic drawing to RDWorks. How can i see if the drawing is in low resolution?
    Thanks a lot!
    Jan 2017
    Draw a circle in the laser software and test. This will take the image out of the equation.
