Laser cuts straight lines slower than curves or circles.
Results 1 to 3 of 3
Thread: Laser cuts straight lines slower than curves or circles.
    Apr 2018
    Default Laser cuts straight lines slower than curves or circles.
    Hi, Needs some help. Have been running a Universal M-300 for years without problems. Engraving and cutting. Recently when cutting the speed is ok on curves but speeds up on straight lines. Consequently need to run the cut one or two more times to completely cut through the material on the straights. Cut corrugated boards and plastics at various thicknesses. Use Corel Draw11 and import dxf files from Inventor. Cleaned mirrors and lenses. Any Ideas?
    Registered Sterob's Avatar
    Jan 2007
    Default Re: Laser cuts straight lines slower than curves or circles.
    Quote Originally Posted by MCobb View Post
    Im confused....does it speed up OR slow down when cutting straight lines?
    Sent from my SM-G920I using Tapatalk
    SkLaser's Avatar
    Apr 2018
    Saskatchewan
    Did something change in the parameters for fast cut conditions? Sounds like all the straight lines are on fast cut, and that the feed rate may be a little too high, or the power too low.
