Cris- someone posted this file on the RDworkslab.com board. Use at your own risk. Gene
Hi everyone,
I have a BODOR BCL1006XUF, 80W CO2 laser machine.
Unfortunatly I lost the file with the vendor settings for my laser machine and I'm really desperate. I tried to contact the seller but they told me that they didn't have the file for my machine because it is an old machine (since 2016).
Can someone please send me the file of the vendor settings, or screenshots of the X and Y axis settings, so I can set the correct parameters?
Here are some details about my laser machine:
BODOR BCL1006XUF
80W CO2
1000 x 600 mm working table
Motherboard: RDC6442S(EC)
Microstep driver: 3DM783 (from JMC)
Stepper motor: 57J1276-526-L-B1
PC-Software: RDWorks V8.01.10
Unfortunatly my laser machine seems losing steps, only sometimes and totaly random and I'm thinking that this is because of the parameters. You can check the issue in the attached pictures.
Also you can see in this video (minute 0:43 , 1:43, 1:49 or 3:19) what it is happening during cutting:
So, if someone has the same laser machine, please help me with the vendor settings for X and Y axis.
Thank you to all of you,
Cris
- Need Help!- I need the vendor settings file for Chinese SGH350 Laser with Ruida board
- Need Help!- Shenhui SH350 - need vendor settings file or screenshots
- Laser Controller Cable Pin out RDC6442S(EC)
- Need Help!- I need the vendor settings file for BODOR BCL1006XUF Laser with Ruida RDC6442S board
- Converting from Ruida rdc6442s to controller with no file size linit
4x4 shopbot with chicom water cooled spindle
3x4 130watt chinese laser
Hey Chris,
surprised that bodor didnt have your settings.
with respects to the skipping steps i had a similar problem on my bodor mini (600x500 bed) which looked like some mechanical failure or too fast acceleratiin/deceleration often when i was doing scanned engraving. Turns out it was electrical interference from the laser tube to the cables going to the stepper. i hacked a solution which was to shield the cables with a metal sheet from line of sight of the laser tube. a better solution would be to replace the cables with grounded shielded cables.
This may be the source of your skipping problem.. or not.. but worth investigating.
Laser: Bodor BCL-0605MU 90W Reci
Router: Carving X6-1500
