Electric shocks in cooling water
Results 1 to 9 of 9
Thread: Electric shocks in cooling water
    Default Electric shocks in cooling water
    Is it normal,? I have chinese machine 80 watt laser (RECI genuine) I used a bucket and water pump as cooler for the laser tube, the water inside the bucket are electrified.
    Is it normal for the water to get electrified from the laser tube?
    Or my laser tube is damaging / broken and that's why it passes electricity into the water.
    Sent from my Redmi 4A using Tapatalk
    Nov 2010
    Poland
    Default Re: Electric shocks in cooling water
    As long as laser works it is not broken.
    Did you check all groud cables in your machine?
    Chinese have only 2 wire wall instalation so thay are not used to make proper grounding.
    Call for electrician to check it.
    CNC lasers, constructions, service
    Member abyss's Avatar
    Oct 2015
    Ireland
    Quote Originally Posted by jmoreno View Post
    good chance it can be NOT laser itself, but water pump. As Cinematic2 told - call electrician.
    Polish @ Éire
    Jan 2017
    Don’t touch the water and you will be good Togo.
    Gold Member MichaelHenry's Avatar
    Jun 2006
    Chicago suburbs
    Quote Originally Posted by engraving_hub View Post
    That's just asking for trouble. Get it fixed or become the next Darwin awardee.
    Member mactec54's Avatar
    Jan 2005
    I would say, your water pump is faulty, and should be replace before someone gets electrocuted, the Chinese supplied water pumps should not be used as they have no Ground, or are not double insulated, check the Machine Grounds as well, they may not be up to code as well, this is a must check for all Chinese Machines, as in China they are not required to use a Ground, which results in lots of deaths from electrocution
    Mactec54
  7. #7
    Thank you very much for your suggestion. But the water is electrified only when the laser tube is workingElectric shocks in cooling water
    Enviado desde mi Redmi 4A mediante Tapatalk
  8. #8
    Jan 2005
    Glad you found what is causing the problem
    That's all the more reason to check all the laser power supply and machine Grounds, make sure they are in place, if they are not, then this is the best place to start
    Mactec54
  9. #9
    Thanks, now I'm using destilate water and change the power supply.
    Enviado desde mi Redmi 7 mediante Tapatalk
