Need Help! I need the vendor settings file for Chinese SGH350 Laser with Ruida board
Results 1 to 5 of 5
Thread: I need the vendor settings file for Chinese SGH350 Laser with Ruida board
    Feb 2018
    Austria
    Default I need the vendor settings file for Chinese SGH350 Laser with Ruida board
    Hi, I did a factory reset on my blue and white sgh350 laser, it has a Ruida board. 500x300 work bed. HMI-V4.1.13.
    Does anyone have the file or can instruct me as to how to configure it? I am using RDworks v8.0
    Jan 2008
    Default Re: I need the vendor settings file for Chinese SGH350 Laser with Ruida board
    Try these they work for my unit
    Feb 2018
    Austria
    Thank you, I managed to get the correct files from someone yesterday, and it is now running again.
    *Registered User* lucho1111's Avatar
    Nov 2018
    Buenas: Tengo un problema parecido. El láser no dejaba de funcionar desde que empezaba hasta terminar, quemandolo todo. Si estaba haciendo un grabado, quemaba todo de lado a lado, de forma continua, y si estaba cortando algo, iba quemando en el trayecto. Así que restaure en la maquina a valores predeterminados, y después valores de fabrica, y ahora si que se ha desconfigurado por completo. Alguien puede ayudarme, o pasarme algún archivo para volverla a configurar? Muchas gracias
    *Registered User* adammada's Avatar
    Jan 2019
    Hi.would you ad this file with vendor settings please.Thank you
