epilog legend 32 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: epilog legend 32
  1. #21
    Jul 2013
    Default Re: epilog legend 32
    So are you then throwing good money after bad?
    Epilogue rebuilds those machines for a fee.
    But if you can get an upgraded laser get it!
    Go for 80Watts
  2. #22
    Jan 2015
    what we did is run the power @ 100% and speed @ 40 i believe so it would cut slow. so i called epilog tech today and to up grade to 50-65w it needs sent to them because there is other things that need done and thats approx 4-5,000 yikes! he also said that @ full power and the slower speed you use and if still takes more than one pass to cut the tube is not good... but he also said cutting 1/8" acrylic with the legend 32 30w is about right. so to me its basically just an engraver... witch is nice but i want it to cut also. doesn't look good does it..
  3. #23
    Nov 2010
    Poland
    Quote Originally Posted by jgstang View Post
    speed @ 40
    Here is the answer.
    CNC lasers, constructions, service
  4. #24
    Jan 2015
    we should have set the speed @ like 10 for a slooow cut.. and its to much to up-grade it, maybe get a cheap k40 or a walmart orion to get my feet wet... and actually i've heard some pretty good things on the cheap ones, but also alot of bad.
epilog legend 32
epilog legend 32
