Need Help! Problem engraving.
Results 1 to 5 of 5
Thread: Problem engraving.
    Jun 2015
    Mexico
    Default Problem engraving.
    Hello,
    I have bought a new machine and it is already installed, but I have a problem when engraving. When engraving in two directions the image comes out doubled and when engraving in one direction it looks like the light does not burn the material equally.
    I put pictures to see if someone can help me.
    This is engraving two direcctions or X_swing
    This is engraving one direcctions or X_unilateralism
    Thank you very much.
    Maypa
    Attached Thumbnails Attached Thumbnails Problem engraving.-img_9511-jpg   Problem engraving.-img_9512-jpg   Problem engraving.-img_9516-jpg   Problem engraving.-img_9517-jpg
    Nov 2008
    Default Re: Problem engraving.
    There’s a setting to align both passes when you x-swing in both directions. It’s in the manual. Just read it carefully.
    Jun 2015
    Mexico
    Thanks for answering my post.
    I think what he says is the Scanning Reverse interva. I think that this option is used to align the bidirectional engraving.
    But the last images that I post are only engraving in one direction and the problem is that the laser light does not burn the uniform material.
    If you look to the right there is like a deformation, look at the image that I add.
    Nov 2008
    not sure. try different settings. I tried it with a 50 W tube at 14 to 16 degrees on a AWC708C. this is on soft untreated wood.
    Problem engraving.-img_2020-jpg
    Problem engraving.-img_2015-jpg
    Jun 2015
    Mexico
    Hello,
    I think he's confused, but thanks for your help.
Problem engraving.
Problem engraving.
