Sorry if this topic has been covered...
I'm new to laser cutting and have begun experimenting with laser cutting fine lace type patterns from suede and leather (approx .5mm).
Is there a way to clean burnt edges of suede or avoid it all together? Any online advice I've found are around sanding or burnishing thick leather (e.g. bag/belt leather) and not cleaning soft suede.
There are Youtube videos showing white leather being lasercut without leaving any burn at all but there is no info attached on what kind of laser cutter or settings. (I can find a link if that helps)
There are also many images online of bags/shoes/garments made of laser cut suede which don't have burn marks.
2 things....
I have access to a Trotec SP500, Trotec Speedy 300 & GCC X252 Laser Cutter
I'm based in the UK (if that makes a difference!)
Thank you for any help in advance.
