Need Help! Removing\preventing residue or scorching for deep engraving on polished plywood
Results 1 to 3 of 3
Thread: Removing\preventing residue or scorching for deep engraving on polished plywood
    Mar 2015
    Default Removing\preventing residue or scorching for deep engraving on polished plywood
    Hello,
    I have an issue with removing\preventing residue or scorching for deep engraving on polished plywood.
    I have used a paint tape to prevent the residue, but when I take the tape off - it creates a lot of pile and need to sand which damage the engraved lettering.
    Can you please advice what I can use in order to get the best result.
    Thanks in advance.
    Member TokinSpokane's Avatar
    Mar 2019
    Default Re: Removing\preventing residue or scorching for deep engraving on polished plywood
    This is an old post but, here it is…
    Spray Aquanet hairspray on the acrylic before engraving. It just rinses off with warm water & no residue.
    TokinSpokane.Removing\preventing residue or scorching for deep engraving on polished plywoodRemoving\preventing residue or scorching for deep engraving on polished plywood
    Sent from my SM-G935F using Tapatalk
    TokinSpokane
    Custom Crafts
    May 2017
    finishing with wax will do trick and painter tape on top of waxed surface.
